So, I am trying to figure out the best way to bind dpad down to rapidly and i mean rapidly spin the right stick starting at 3 o'clock and going clockwise for a game, it is the only keybind i need to really beat this game. Anyone more experienced than me know a good way to do it?
Need Help Figuring Out A Keybind
 reWASD does not have a "spin the stick" mapping, but you can make a [Combo] that would do something similar. Record a [Combo] or set it up manually (recommended) so it would move the stick to each of 8 directions at 100% relative deflection and enable the [Turbo] option for the mapping. Make sure to set the pause nodes of 50-100ms at the points where you want the game to register the stick position, and don't forget to take "relativity" into account (you would need to have two X-axis nodes at 100% to move the stick from left position to right).
 Case #19 will help you set up the nodes' values.
