Rewasd locks my desktop I can't click on anything
  • Rewasd locks my desktop I can't click on anything
    Rewasd masaüstümü, faremi ve klavyemi kilitliyor. Güç kapatma ve etkinleştirme düğmesi takılı olmasına rağmen. Bazen çıldırıyor ve kapanmıyor, devre dışı bırakıyor. Bu arada faremin bazı klavye hareketleri yapmasını sağlayabiliyorum ama tıklamıyor. Yardımınız için teşekkürler. (son sürüm)
    To disable remap at any moment, use the CTRL+ALT+DEL shortcut.
    Your config unlocks the mouse using the [Home] key (toggles to Shift Layer #4).
    Note: On short keyboards, you might need to hold the [Fn] key too.
      Sometimes it doesn't switch. I WANT TO CLOSE IT WITHOUT USING CTRL ALT DELETE.
        reWASD does not have a random condition for whether something works or not. The [Home] key should switch to the fourth layer from any other layer.
        Please follow the instructions in case #24 here to ensure that your devices group has the correct mouse and keyboard in it.
          I only have 1 mouse and 1 keyboard
            Please make a short video of the issue. Make sure the reWASD window, the devices group editor, the moment you press the [Home] key on your keyboard, and the result is visible.
