Hi, I just installed an 8Bitdo GameCube controller mod kit.
and then realized afterwards that it only transmits Switch Pro controller signals for PC, and DINPUT for Android devices.
So since it's being detected by Windows as a Switch Pro controller I'm not able to use the analog of the triggers.
Do you know if it would be possible to "intercept" the DINPUT signal of the controller using REWASD?
People are saying that DINPUT works with analog triggers on Android.
I was using an 8Bitdo GBROS adapter and that worked well for the analog triggers since it transmitted an XBOX controller signal. But I saw that mod kit and thought it would be nice to not have the cord anymore.
Do you guys have any plans for supporting that mod somehow?
Thanks!
Thanks!
