In researching my first gyro purchase, I've come up with a few questions specifically for Vader 3 Pro + reWASD users. I'm focusing on this hard/software combo because it's my understanding that it's the best (if not only) setup to get the functionality I'm looking for. I'd really appreciate some clarification on some things before I pull the trigger, if you'd be so kind:
1. I've read that reWASD recognizes the Vader 3 Pro as its own proprietary device, and allows using gyro and analog triggers simultaneously in wireless mode. True?
2. Using reWASD, will it be possible to bind the Vader's rear buttons to enable gyro while pressed (or use the rear buttons to toggle gyro)?
3. Since PC games overwhelmingly do not support gyro natively, I assume many games may have "glyph flickering" while gyro-as-mouse is enabled. Is that generally the worst problem, or do many games struggle to provide a playable experience in these circumstances?
4. Reading the reWASD license descriptions, it's not clear whether I need any optional features to achieve the functionality I want (toggle gyro with rear buttons, using roll and/or yaw for mouse x-axis). Do I just need the basic 7 dollar license?
5. Lastly, for most games that aren't aiming and shooting focused, I just want the Vader to act as if it's a 360 controller. Is that trivial to set up? Without reWASD active, does it basically act as such?
I know that's a wall of text, so I very much appreciate your time and support. I'm keen to get into this whole gyro thing, but I really need to get everything right with this one purchase. Thanks a million!
