I’m trying to take my gameplay to the next level by mapping multiple buttons to a single key, but I’m having some difficulty figuring out how to set this up properly.
Specifically, I want to map two or more controller buttons (such as L1 + R1) to act as one single button press (for example, the "A" button) in certain games. The goal is to have both buttons activate the same action simultaneously without needing to press both individually. I’ve checked the documentation and tried experimenting with the “Combo” feature, but I’m still not sure if I’m doing it right escape road or if there’s a better way.
Has anyone else here successfully done this? Could you guide me on the best way to achieve this functionality in ReWASD? Any tips or tricks would be appreciated! Also, if there are any advanced settings or features that might help with this, feel free to share those as well.
Thank you.
Thank you.
