So I recently bought (and am returning) a Razer Wolverine v2. I bought it cause the 6 extra buttons, that end up being very limited on how you can remap them. So limited, it's essentially pointless. Unfortunately, ReWASD doesn't recognize those buttons, which I'm aware isn't their fault or doing. So, to the point of this:' What is a great controller, with extra buttons and/or triggers that work well with ReWASD?
What's the best controller with remappable extra buttons?
Hi!
I can suggest you look at something like Flydigi Vader​/Apex controller or Xbox Elite Series 2
Please note that Flydigi Vader​/Apex​ 4 is currently unsupported, but support for Flydigi Vader​ 4 should arrive by the end of this year.
Also, a full list of supported devices can be found here: https://help.rewasd.com/how-to-remap...d-devices.html
I agree with Gogeba I use the Vader 4 PRO and it works fantastic with all games on PC. The latency and polling rate compared to other controllers is outstanding. I would never go back to any other controller since I started using them over the last 6mths. I have the Vader 3 PRo too, which works great with ReWASD and so will Vader 4 Pro when its supported soon.
