Nacon Revolution 5 Pro as Xbox Elite controller
  • Nacon Revolution 5 Pro as Xbox Elite controller
    The Nacon Revolution 5 Pro controller is designed for PS5 consoles. This controller has 4 paddles. Also has the option to switch to PC compatibility. When I connect the Nacon controller to ReWASD as PS5 it will detect a regular PS5 controller. No paddles. If I switch the controller to PC, ReWASD will detect an Xbox 360 controller. No paddles either. Is there a solution to make ReWASD recognize the Nacon paddles?
Name:	nacon 360 controller.png
    Hi!
    Unfortunately, reWASD is not able to detect the additional buttons/paddles, since they are not reported to Windows as separate controls, unlike Xbox Elite 1 and 2 paddles.
    At the same time, a workaround has recently appeared that can help in remapping additional buttons of other controllers using their native software.
    I cannot guarantee success, but you can try this method:
