Delta force assigin 2 buttons to activate from 1
  • Delta force assigin 2 buttons to activate from 1
    Delta force On my setup click in left controller knob activates breath so can I set it up where when I press left trigger to ads it also activates left stick controller to breath and when I release trigger it also stops the breathing? Thanks
    you can assign it to ADS as a combo. So when you click on aim or right mouse button combine it with shift or breath. Every time you aim you breath.
      I wanted to add an image but I am not approved to modify my original post. Click image for larger version
