Is it possible to share some mappings between layers 1 and 2, and other mappings between layers 3 and 4?
layer group
Hi!
Yes, you can share mappings between Layers 1 and 2, and between Layers 3 and 4, easily by using the Copy and Paste feature for Shift Layers in reWASD:- Right-click on the Shift Layer you’ve already configured and select Copy.
- Select the next Shift Layer, right-click, and choose Paste.
This will duplicate all mappings from one layer to another. You can then tweak the layers to add unique mappings if needed.
