Delta Force Banning
  • Delta Force Banning
    Heads up. I was banned for 24 hrs because I had ReWASD in the background but not running. There is no point to use ReWASD with Delta Force becasue they don't currently support controllers or mobile. They will be supporting these platforms in Janurary but they banned me regardless. I am trying to fight it becuase they are essintially say that they get to tell me what applications I'm allowed to have on my computer.
    Hi!
    While reWASD itself doesn’t interfere with games unless you actively configure and apply profiles, it does include features like Combo and Rapid Fire (Turbo), which some multiplayer games may consider a violation of their terms of service. It's important to avoid using these features in online multiplayer modes to minimize the risk of being flagged.
    However, even if no profiles are applied and reWASD is only running in the background, certain anti-cheat systems may detect its presence and issue bans based on their own criteria. Unfortunately, we do not control or influence how games or platforms enforce their rules.
    To avoid future issues, we recommend fully exiting reWASD from the system tray when playing games with strict anti-cheat policies.
      Ya. Lesson learned. I've got a support ticket because I want to know if having the software on my computer, even not running, will trigger a ban. They are using kernel level anti-cheat which I am not sure they can detect what programs are installed or not.
        Originally Posted by Kapas View Post
        Hi!
        So I have found out that their kernel level anti-cheat will flag your account for having the software installed on your computer. It does not have to be running for you to get flagged and temporary ban.Does ReWASD have a portable version of the software I could install on a USB so that I can remove it from my computer?
          Unfortunately, reWASD does not have a portable version that can be installed on a USB drive or run without being installed on the computer.
