Duplicate input from Azeron stick
  • Duplicate input from Azeron stick
    Something must've broken recently, because I was playing helldivers 2 just fine a few days ago (literally the only reason I purchased subscription for)
    I have Azeron Cyborg v2 and I mapped the stick to the WSAD buttons, and it was running just fine for a few days. Today I tried to play again and noticed 2 things:
    1. reWASD no longer detects helldivers 2 exe, I have to manually apply it to slot
    2. The UI in game flickers between keyboard and controller buttons
    3. As soon as I activate remap a virtual controller named "xinput" with Azeron stick bound to left stick comes up visible in gamepad tester as well (this seems to be whats messes up my game) despite stick being bound to keyboard and not controller stick
    How do I fix that?
    Hi!
    Let’s try these steps to fix the issue with your Azeron Cyborg v2:
    1. Clear Data:
      • Go to reWASD Preferences > General and select "Clear Data." This will reset your settings. Restart your PC afterward.
    2. Reapply Autodetection:
      • Follow the steps in this guide to ensure reWASD properly detects your game and controller.
    3. Unmap Default Keys:
      • Make sure all keys on the Azeron stick are unmapped to avoid duplicate inputs.
    4. Check Virtual Stick Mapping:
      • Confirm that the Azeron stick is not mapped to the left stick in the virtual controller. Use Device Detection mode to check for overlaps.
    5. Test in Gamepad Tester:
    Let us know if the issue persists or if you need further help!
      No luck,
      Followed all that and it still outputs virtual xinput as soon as I enable remapping, whats weird is that I don't even have ANY virtual controller enabled and disabling remapping from UI does not stop that weird xinput thing, but turning remapping off from tray icon menu does. Not gonna lie, it looks like some spaghetti code is spilling out here.
        Hi. Please send us a screenshot of the FULL reWASD window with your mappings, as well as a screenshot from the Output device settings.
          I figured out what the issue was, my driver for azeron somehow got corrupted, had to manually reinstall it and now the double input is gone. Game still does not detect automatically, but it's the only title which has that problem and I found an old thread about that stating it's a known problem so I guess there is not much to be done here.
