I encountered a problem about the delayed switching of shift layers: I set the "a" key to switch from layer 1 to layer 2 after a delay of 1 second, and at the same time set the "b" key to switch from layer 1 to layer 3 immediately. Now I am first in layer 1, and I press the "a" key at first, and then I want to switch to layer 3 so I press the "b" key. I found that rewasd will switch to layer 3 but then switch to layer 2, but I want to stay in layer 3. So is there an option to cancel the delayed switching caused by the "a" key after I press the "b" key to switch directly?
delay shift
