Dualsense edge behaving strangely
  • Dualsense edge behaving strangely
    When I connect it via bluetooth, I get the popup "config 1 active in slot 1". But when I want to start charging it, I plug the usb cable in and that causes the prompt "config 1 active in slot 1" as well. (And it causes my game to give keyboard prompts when wired with rewasd running, but I think this is an issue with the game). And sometimes, even when rewasd says it's paired to bluetooth, I can plug in the usb, and when unplugging it the program thinks the controller is disconnected! I have no idea what's going on. It shows as still being connected in devices and printers after being unplugged, until you go to properties, then it isn't listed.
    That's how it should be. Depending on the connection mode, the controller will appear in reWASD as two different devices.
