I'm not sure how long this has been happening as all the games I've played recently have just used the standard inputs. However, when trying to make a layout, I've started hitting an issue in which the UI will crash. This makes it impossible to create profiles/layouts. Please assist.
rewasdUI crashing
Please check for errors in Event Viewer by following the steps below:
1. Press the Windows button, type [Event Viewer], and press Enter.
4. Once you find one or multiple events, please right-click and "Save selected events..." on every one of them, and send the file(s) to me.
