Is there a way to use rewasd from a steam link?
  • Is there a way to use rewasd from a steam link?
    I usually use Steam link to play games, but the controller mapping doesn't seem to work when I connect to Steam link.
    Is there something else I need to set up?
    Hi!
    reWASD can work with Steam Link, but some additional steps may be needed:
    • Make sure remap is active before launching Steam Link – enabling it after starting the stream may not work.
    • Disable Steam Input in Steam, as it can override reWASD mappings.
