Rewasd sensitivity go crazy
  • Rewasd sensitivity go crazy
    so I remap my M&K to controller and it was working fine but now I don't know why after I enable rewasd and use it for like 10 second its just triple my controller sensitivity and its became un usable.
    please help I cant use the software anymore like that
    Hi!
    It sounds like there might be a conflict with sensitivity settings or an unintended input loop. Please try the following:
    • Test the virtual controller in Windows (joy.cpl) to see if the sensitivity issue happens there too.
    • Try clearing device cache in reWASD: Preferences → General → Clear data, then restart the app.
    • If using a mouse-to-stick mapping, adjust the Response curve in reWASD to prevent acceleration spikes.
    If the issue persists, please provide a screenshot of your config
      Hi Kapas,
      1.the issue still happens in the joy.cpl​ test
      2. did it and its still happens
      3.even when I use you Default one its still happens.
      I upload my config here but I don't think its a config problem because i tried different ones and its still happen
      please help.
        Hi. Unfortunately, we were unable to reproduce this issue, and the sensitivity remains stable. Please send us a video showing your issue.
        Also, please send us the file with system information. It doesn’t include any personal data but shows active processes, installed apps and drivers.
        3. Go to File -> Save
        4. Send us the *.nfo file you get.​
          here is the nfo file:
          here the video:
          you can see when I start rewasd its move with the right sens but after couple of seconds its just go crazy its go up and up with the sens
          if you need something else tell please
            It’s likely something on your PC’s side, as we’ve tested this on multiple PCs, and everything works correctly.
            Shift Layer 1 has higher sensitivity as it should, but if we understand you correctly, this doesn’t seem to be related to the issue.
            To rule out any potential problems with reWASD, go to Preferences and perform Clear Data. Also, try recreating the config from scratch.
              ok so just letting you know I think I fixed it for now, what I did is replace the Virtual Xbox One to the Virtual Xbox 360.
              I think because the Virtual Xbox One is bluetooth connected its break something with my windows, really weird.
              thanks for trying to help and if something breaks again I hope to get your assistance again hope not too soon .
