Hello. Havent been here for a bit. Im testing my Xbox Elite 2 controller on https://hardwaretester.com/gamepad When reWASD 'magic' is off the gamepad works fine. But when I turn the 'magic' button to on to enable the current default basic Config1 my left joy stick gets inverted controls. My up is down, down is up etc. Its only for the left stick. The software did not use to have this problem and I have only used it very minimally in the past with out issue.
Left stick inverted controls
