Customization
  • Customization
    Hello, I reinstalled Windows and again I can not understand why my rewasd does not work.I detected the mouse and keyboard correctly, I think the problem is that when you switch slots in the game, the game pad does not turn on.Click image for larger version
    Hi.
    Could you record a video that will show your device group and the configs that are applied to different slots?
    Also, please clarify what exactly is not working?
      when you switch the slot, you should change the name of the key on the interface, this does not happen, so I think the problem is that it does not switch to the gamepad
      [link expired]
        It seems you confused me by mixing up the slots with the Shift layers.
        Apply the config and check it here.
        If the virtual gamepad works correctly in the tester, then you should try applying the config and only then launch the game.​
