Problem - REWASD mappings fire alongside game default mappings
  • Problem - REWASD mappings fire alongside game default mappings
    I haven't run into this problem yet (kinda surprised) and I've used REWASD for a year or so. I recently got Avowed from the gamepass and the game's button inputs trigger on top of my REWASD mappings, this obviously doesn't work very well. How does one ensure a program only uses the REWASD mappings?
    SOLVED
    Yeah I found the "Native" button which I had never used or seen before really. Worked like a charm.
    Hi!
    Please try using the Magic Wand option in reWASD and select Mute all. This will disable the input from your physical controller and ensure that only the virtual mappings are applied in the game.​​
      Yeah, didn't know muting was an option. Thanks for the reply!
