Is there a way to set a timed mouse movement to a controller button?
  • Is there a way to set a timed mouse movement to a controller button?
    It's a little hard to phrase, but essentially: I want to be able to quickly flip my camera around similarly to Resident Evil 4(holding down+A), or Left 4 Dead's feature.
    Since I can't set mouse movements with combos, is there another way to accomplish this?
    Unfortunately, there is no other way to emulate a virtual mouse yet.
    But mouse movements by coordinate via combo are in our plans.​
      It is quite possible that the flick stick functionality can help you.
        Oh, this is almost perfect!
        Is it possible to get flick options on a button, rather than a stick?
          Hi!
          Currently, Flick Stick is designed to work with analog sticks, anw we recommend checking out the detailed explanation of its functionality here.
            Thanks for all the info. Are there any plans to expand flick stick to buttons/triggers in the future?
              There are no current plans to expand it to buttons or triggers. However, we appreciate your suggestion and will forward it to our team for consideration.
