Hello, wired Switch Pro keeps losing gyro utilization in Fortnite. Got it to work once or twice, but it keeps "forgetting" gyro functionality when all other buttons work fine automatically without having to program anything. And half the time when I manually try to program gyro it still won't work, period
Please explain how reWASD is related to this issue. Are you remapping your Switch Pro to a virtual DS4?
Have you tested the gyro outside the game? We suggest using the Game Controller Tester for that.
Do you have any mappings that toggle or turn off the gyro in your config?
I think you should try using reWASD to remap your Switch Pro controller to a virtual DS4. You should also test the Fortnite external gyroscope with Game Controller Tester to see if the issue is with the controller itself.Originally Posted by Huber_z View PostHello, wired Switch Pro keeps losing gyro utilization in Fortnite. Got it to work once or twice, but it keeps "forgetting" gyro functionality when all other buttons work fine automatically without having to program anything. And half the time when I manually try to program gyro it still won't work, period
