Kingdom Come Deliverance 2 Controller Double Input
  • Kingdom Come Deliverance 2 Controller Double Input
    Whenever I turned on ReWASD remap, I get double input in-game. I am using Xbox Elite 2. When I turn off remap, controller works fine. I tried HidHide bit it just crashes when ReWASD is running. It might be a game issue, but in case it is not and someone found a solution, please do share. Thank you.
    Make sure all your remapped buttons are [Muted]. If they already are, unmap all the paddles on all profiles via the Xbox Accessories app. Check this article for details.
      This issue only happens with Kingdom Come Deliverance 2. ReWASD works fine with other games I have.
      Paddles are unmapped already.
      In ReWASD, all buttons are muted as well.
      I misunderstood the instructions and how reWASD works. I did not map the the other muted buttons in reWASD.​ So those buttons did not work ingame.
      Thanks for the help. It is working now after mapping the muted buttons to their respective functions.
