I've created a combo for my controller where I push my right trigger (RT) and the combo performs a movement with the right analog stick going down and then back up. Simple.
However, I need the movement in the right stick to differ when going down and then back up. What I need is for the movement downwards to be slow and the movement back up to be faster.
In the combo that I've created both movements happen very quickly.
Is there a way to adjust the time taken for a specific action to occur within the combo?
Thanks
Thanks
