Is there a way to make it so that, in reWASD combos, you can hold a button down and press another button without releasing the first button and have it execute a key stroke? I'm a stalker player and unfortunately, due to the fact that my mouse is currently having issues, I have to find an alternative way to play and the original trilogy of stalker doesn't offer any controller support. This is my only answer and the original trilogy of stalker has a lot of controls on the keyboard and mouse and therefore, I have to find a way to map every single button I need onto a controller. I'm trying to set it up so that I can perform actions with my sights pulled up since there are so many buttons that need to be mapped. The way that I want to be able to do this is to have some of my combos set up to where I can hold LT (Sights) and then press a button and have it perform that action without me needing to let go of LT, which would cause me to lower my sights and lose my target, in order for it to perform said task. This would allow me to more strategically map combos for things like my select fire which is only one of many many different buttons I would need to map through combos. If anyone has any good answers, I would really appreciate it.
Combo button presses and releases.
