**UPDATE** ReWASD Ban in Arena Breakout FIX
  • **UPDATE** ReWASD Ban in Arena Breakout FIX
    So, for those that are getting banned in #ArenaBreakoutInfinite I was too until I did the following and now it works...
    So, first off, it was nothing about using ReWASD. I have remapped my ABI files as they are different from the last time, probably due to an update. It use to be TSI.exe, but now they are these ones below:
    UAGAME.exe
    Gameloader.exe
    arena_breakout_infinite_launcher.exe
    I uninstalled MSI Afterburner and Riva Tuner too, so first off just trying the above. If it doesn't work, then try to uninstall these.
    Hopefully it works for you!
    Hi! Thanks for sharing this info! We'll keep an eye on this issue.
