When using mouse and key to emulate a controller I have the left mouse button on a combo to control recoil. If I copy commands from configs from any profile it will completely break the combo and render it useless. I didn't realize this was happening at first and went from tweaking the combo to completely overhauling it not realizing no matter what I changed it had zero impact on stick movement. For instance the recoil would move to the right so I would change right stick left/right to -50 and it would still drift to the right. I then deleted the entire combo script, redid it and it went back to normal. But if I made an error or a significant change, it would go back to not recognizing the changes.
While I am at it, every so often the profile would lose settings. I would have to turn the magic off and then back on and it would be business as usual.
