Hi everyone,
I’m in desperate need of help configuring my Ducky One X keyboard with analog actuation. My goal is to map the "W" key so it behaves like the trigger on an Xbox or other console controller, where pressing harder gives more gas and pressing lighter gives less gas.
Unfortunately, I’m struggling to figure out how to achieve this using the reWASD software. I’ve managed to activate a virtual controller, but I can’t seem to get the mapping to work as intended. The process is more complicated than I expected, and I’m feeling quite stuck.
Ideally, I would love it if someone could share a pre-made configuration with me, or guide me step by step through the process. I’m not very familiar with all the settings, and the software feels quite overwhelming to me.
I’d really appreciate any help you can offer. Thanks in advance for your support!
Best regards,
Math7as​
Best regards,
Math7as​
