Vader 4 Pro not recognized in REWASD
  • Vader 4 Pro not recognized in REWASD
    I recently purchased a Vader 4 pro after finding out REWASD now offers native support for it, however it only is recognized as standard xbox 360 or switch controller. I have tried all connection methods, both wired and wireless. I've also clicked the "Clear Data" button in Preferences. Using latest version 9.1.1.10162. Any suggestions?
    Hi.
    We support Flydigi controllers only in D-input mode.
    So, ensure you switched your controller to D-input mode(the corresponding indicator should glow blue afterward).
      Yes, the connection toggle is in D-input mode. (Position on left?) In this mode it is recognized as xbox 360 controller. The connection light does not glow blue in this mode, it glows white. In NS mode (toggle button moved to right) it glows blue. I have tried all connection modes, both wired and wireless. Oddly, in Android/iOS mode (Bluetooth wireless; toggle in middle) the controller is detected as an Xbox One controller. When I first startup rewasd with the controller I see a screen telling me to put it in android mode to get the most features. See attached screenshots.
        Moving the switch to the left side is not enough.
        Please check the image below:
          Thanks for you help, finally got it figured out. Shows up as Vader 4 pro in the software. x and d input switching is what confused me. I now know you can switch between the two in either wireless dongle or bluetooth mode. Thanks again!
