My controller won't get out of DS4 πŸ˜“
  • My controller won't get out of DS4 πŸ˜“
    I have 2 controllers that Windows always recognizes as 'Controller (Xbox 360 for Windows)' in joy.cpl.
    Today was the first time I went to use reWASD. So, reWASD was already running, and then I connected the USB dongle in my PC to use my wireless controller. But as soon as I connected the USB dongle, reWASD showed me the following pop-up: 'DualShock 4' - Disconnected, and my USB dongle stopped working at that moment (the red light turned off, and then I connected it to another computer, and it doesn't work anymore).
    Since then, my controller has been automatically recognized natively as DualShock 4, even being able to 'emulate' an Xbox 360 controller. Now every time I connect my controller, even with reWASD uninstalled from the system, it is recognized as a PS4 controller (even by Steam itself).
    I need help ;( I have uninstalled and restarted multiple times, but it doesn't return to the original state of the Xbox 360 controller. Since the dongle no longer worked, I connected it via cable and it always recognizes it as DS4
    What you are describing is something very strange, and it is unlikely that it is caused by reWASD.
    Our software affects your devices at the software level (not hardware) and only while the remap is enabled. This means that if you connect the controller to another device, the reWASD changes will not work. Likewise, if you removed the reWASD driver from the system when uninstalling the program.
    It seems to me that the key to the mystery should be sought in the controller or dongle itself.​
    However, could you please specify the model of the device that is causing the problem and its dongle? Ideally, please indicate where you purchased the device and also send a photo of the back of the gamepad.
    Thanks in advance.​
      No se si podra ayudar con el tema, yo tengo muchos mandos, ayer justo recibi el vader 4 pro, el problema es que windows se "queda" con muchos mandos "conectados" pero solo hay en realidad uno, va a configuraciΓ³n de bluet... y otros dispositivos y ahi quita el ds4 si aparece de alguna manera debes dejar solo el mando que sabes que funciona, en windows
      espero haberme explicado bien jeje
        To be honest, it’s not very clear and, moreover, I think you should create a separate topic.
          Later I will record a video showing the problem. I think it will be easier to understand!
