I bought an ESP32-S2 and it has an ESP32-S2FNR2 chip (revision v1.0) and it has all the drivers installed and it keeps giving me an error installing the firmware even after entering BOOTLOADER mode (holding the BOOT button, pressing RESET and then releasing BOOT) I have downloaded esptool.exe inside the corresponding folder and I have seen that there are different .bin files depending on the board, but I don't know if mine corresponds to any of those and I have done everything indicated in the corresponding article (https://help.rewasd.com/external-devices/esp32-s2.html) and it keeps giving me an error. It should be noted that it is ESP32-S2 mini and only has a USB-C port, I am waiting for a UART-USB A adapter, so I do not know if you have to connect from the USB that acts as UART or with the native that brings the board would work.
Thank you.
Thank you.
