Weird rumble behavior in Rematch (Dualsense Edge)
  • Weird rumble behavior in Rematch (Dualsense Edge)
    I added rumble for FN button that itself has a shift function to another layer. The problem is that in game (Rematch) rumble behaves differently from what I can test without the game opened, Dualsense Edge rumbles with less force and only on one layer, meaning if I switch back by pressing the same button, there won't be any rumble at all. If I remove shift function rumble will work intermittently, like every 5-6 presses. Maybe it has something to do with easy anti-cheat? Profile attached
    Hi. Could you please check if this issue occurs in other games?
      Checked on Elden Ring: Nightreign, another game with EAC, everything works correctly. Seems to be affected in Rematch only
        If this issue occurs only in a specific game, then it is not related to reWASD.
        Please try changing the type of virtual controller in the Output device settings and disable controller support in Steam.
          I have disabled controller support and with xbox emulation it works correctly as well. As soon as I change to Dualsense Edge, rumble with go off only every 3rd press (if shift function not binded, that way it'll be every second press)
            If everything works fine in other games, then it's definitely not caused by reWASD — the issue is related to how this particular game handles vibration.
              Specifically with Dualsense Edge? It just sounds a bit weird, all other options work, but I guess this is how it is
