Controller remapping question
  • Controller remapping question
    I'm an occupational therapist working with a client who wants to play PC games using a PS5 controller. The challenge is that they can only use their left hand, so they can't reach the buttons on the right side of the controller.
    I'm looking for help to determine if reWASD can be used to toggle between two controller profiles: one with the default mapping and another where the right-side buttons are mirrored or reassigned to the left side.
    Ideally, we want the user to be able to press a keyboard key to switch between the two profiles on the fly, allowing access to all functions without needing both hands.
    Has anyone implemented something like this in reWASD? Is it possible?​
    Hi. Yes, you can remap the buttons on your controller however you like in different shift layers.
    To switch between shift layers using your keyboard, you need to group your keyboard and controller.
