When I apply profile with adaptive triggers settings configured, I hear motors move inside of the controller, but when triggers pressed settings are not really applied, they are default. Also LED settings are being overwritten too, even with "Prevent other games..." checkbox enabled. All works okay outside of the game. I see that the game can overwrite some stuff, but why does rewasd let it do that then?
Adaptive triggers settings and LED doesn't apply in Rematch (Dualsense)
Controllers usually accept LED and trigger scheme changes from anything. Unfortunately, the "Prevent other games..." option is not absolute and cannot block all requests.
If you are not using unique DualSense features in the game, you can try remapping it to a virtual controller (DS4, or Xbox One/360), which should stop the game from changing the LED and adaptive triggers settings.
