Xbox Elite 2 paddles not being detected in reWASD?
  • Xbox Elite 2 paddles not being detected in reWASD?
    Hi all,
    I recently got the Xbox Elite Series 2 controller and I’m trying to map the paddles using reWASD. However, it seems like the software isn’t recognizing the paddles at all. I can remap buttons like ABXY and triggers just fine, but nothing happens when I try to assign actions to the paddles. grade calculator
    I’ve checked that the controller is connected via USB, and firmware is up to date. Am I missing a setting in reWASD to enable paddle support? Or is there a workaround?
    Any help would be greatly appreciated. Thanks in advance!
    Hello.
    Xbox Elite 2 has long been fully supported in reWASD
    Try Clear data via Preferences → General.
    If after this the device is again detected not as Xbox Elite 2, then specify the following:
    How is the device detected in the GUI (name)?
    Hover the cursor over the device in the lower left corner and send information about the VID/PID of the device.​
