Crosshair Offset
  • Crosshair Offset
    Am I missing something? Is there no way to adjust crosshair offset? Using a Lenovo Legion Go, and the crosshair is off centre! "Confirmed" with a target practise map. Fwiw this is fullscreen windows mode
    Hi! We’ve tested the Custom Crosshair feature on various systems, and it’s typically centered correctly. However, the slight offset might be caused by how this specific device handles screen scaling or windowed rendering.
    We do have some presets for crosshair positioning, but in the future, we may add more advanced customization options.
