Issue with FC 25 DiscSoftLTD (Daemon Tools)
  • Issue with FC 25 DiscSoftLTD (Daemon Tools)
    I have issue with reWasd and FC 25. It has been 1 month that the issue happening and I keep updating reWSAD again and again but no solution so far. The only way I can play the game is to uninstall reWSAD.
    Here is the error message
Name:	Screenshot 2025-09-11 023434.png
    Any thoughts or ways to get rid of this .. 1 month and no solution.
    I am running now this version of reWASD:
Name:	Screenshot 2025-09-11 023826.png
    Hi!
    Yes, there are no actual solutions at the moment, but we are continuing to search for a way to fix this issue.
    But there is a way to play games you want without uninstalling reWASD, more info here: https://www.reddit.com/r/rewasd/comm...portant_update
      Unforteantly, I updated to 9.1.4 and Emergency Disable Driver is gone. But the issue still persist
        Please enable the [Compatibility Mode] (available in Preferences > General), restart your PC, and check if the game works for longer than 5-10 minutes.
          After enabling that option, The game crashes after 5-10 mins now. What does that mean?
            Hi! We’re working on a fix.​
              Same with FC26 Cant run the Game, Even if i stop rewasd its not working
                Hi! Please update to the latest version of reWASD (9.1.4.10529) from our site and enable the Compatibility Mode at Preferences > General.
