Hi all, I’m Skyler and still pretty new to reWASD. I’ve been experimenting with stick zones because I wanted one part of the left stick to handle camera panning and another zone to act as a quick shortcut when I press it past a certain point.
The mapping works fine until I add a Shift layer. Once the Shift is active, the outer stick zone seems to bleed into the regular mapping, so I’ll sometimes trigger both actions at once. It doesn’t happen all the time, but enough that it makes the setup unreliable.
I’ve checked my zone ranges and curves a few times, and they look fine. Could this be a limitation with how zones and Shifts stack, or am I missing some setting that prevents overlaps?
Would love to hear if anyone has tackled this before, since I haven’t found much about it.
Thanks!​
Thanks!​
