I have an Azeron Keyzen and it shows up in reWASD as a keyboard and an Xbox controller. I was using it without any problems for a while. Then I updated my version of reWASD. I had reWASD installed in my D drive and when I upgraded, it installed it to the C drive. Then when I started reWASD it said that it detected an older version in my D drive and it wanted to uninstall it. I clicked yes. After it did its thing, the keyboard half of my Keyzen is now greyed out. The Xbox is still fine. Because it's greyed out, none of my mappings work anymore. Does anyone know what could be wrong?
Greyed Out Device That's Connected
reWASD doesn't yet fully support Azeron Keyzen.
If you claim your device worked correctly with a previous version, you need to recreate the conditions under which it worked.
Completely uninstall reWASD from both drives and install the previous version (the one your device worked with) on drive D as before.
You can find previous versions in your personal account.​
