When using ReWASD with my PS5 controller, there is severe input lag where button presses take upwards of 10 seconds to register. A lot of times, button presses aren't being registered at all. This is verified via the virtual controller tester. An egregious example is that I would tilt one of the joysticks in a particular direction and I see the virtual controller tester joystick has not moved at all and stays centered. Also frustrating when I am spamming the tester key combo to try to bring it up because I am assuming the inputs just aren't being recognized.
I am not sure why this is happening as I am able to use reWASD with this same PS5 controller on a separate computer with zero issues and tinkering.
Any help is appreciated.
