Too stupid to add Dualshock touchpad to my Legion Go controller
  • Too stupid to add Dualshock touchpad to my Legion Go controller
    OK…I can play PS Plus/Remote play PC app just fine on my Legion Go - until I need to use the touchpad
    So the LeGo controller registers as Xbox controller and I just want to add a touchpad touch to a double click on dpad right.
    Using the remote play 2023 preset, just nothing happens when I do. Not sure if I actually applied the changes or activated them.
    Adding the .exe for the actual app I can‘t map PS Dualshock actions any longer.
    Hi!
    Please try to apply your config manually and test it here: https://hardwaretester.com/gamepad
    Ensure that you have a DS4 controller as an output device here: https://help.rewasd.com/basic-functi...-settings.html
    Also, please send me the config you are using.
    Your configs are stored here: C:\Users\Public\Documents\reWASD\Profiles I need the correspondent *.rewasd file.
      Thanks, it just worked the next day (although I had restarted several times already)
