Currently to toggle the mouse's DPI on-the-fly, there is a DPI button that I press on the mouse, during FPS games.
I would like to be able to hold a button that would 'shift' to a DPI, only while holding it.
Does Rewasd support adjusting the mouse DPI or sensitivity, and across different layers?
Also, does Rewasd support, for example, pressing a key on the keyboard to trigger a layer shift on the mouse?
In case I want to press and hold, for example, the alt key, in order to shift to a layer with a lower mouse sensitivity.
Thanks,
Dean
Thanks,
Dean
