Radial Menu doesn't Appear with Cyro anymore.
  • Radial Menu doesn't Appear with Cyro anymore.
    I just start using Cyro with Rewasd. At first the Radia menu still appear.
    But then I group it with my keyboard. The Radial Menu not appear.
    Ungroup it, the radial menu on my keyboard work. But Cyro Radial menu doesn't appear anymore.
    Hi!
    Could you please send the config you are using?
    Your configs are stored here: C:\Users\Public\Documents\reWASD\Profiles I need the correspondent *.rewasd file.
    Also, try changing the order of devices in your group; this may solve your issue.
      Here, The Radial Menu doesn't appear on Default Cyro anymore. Make new Profile also not working.
      Default Rog X is my Keyboard and mouse. Radial work until I group it with Cyro.
        Thanks for providing the configs.
        Could you also record a video to illustrate this?​
          Here: https:/. /www.youtube.com/watch?v=w2d1E0fABXI
          Every time my cursor stop is because I'm holding the Radial Menu Key. Seem like I can still press key in that Layer like 1 0 as shown. But the Radial Menu does not appear.
          For the keyboard and mouse profile it work fine until I add Cyro to group.
          When I first use Cyro with Rewasd, the Radial Menu work fine. Now even if I'm not Group Cyro with any device or create new profile. Cyro Radial Menu just not appear.
            Here is the link to the video: https://youtu.be/w2d1E0fABXI
              Try Clear Data via Preferences → General.
              Then group the devices again and test the radial menu.​
                Okay, Clear Data work. Radial menu on Cyro is working again.
                After some testing, I think the problem is I already have a Different profile apply to my Keyboard then I group it with Cyro which also have another profile.
                Turn off all profile before grouping work.
                Thank you Y'all.
                  We are always glad to help
