It seems EA found their way around emergency driver uninstall?
  • It seems EA found their way around emergency driver uninstall?
    A few days ago I installed the new version and enabled this before opening battlefield, was fine. Now the toggle does nothing, I just get "the software cannot be used at the same time as the game, please make sure it's not running discsoftltd (daemon tools)"
    Hi. Yes, unfortunately, the only option at this time is to uninstall the software. However, we are already working on this issue.
    If you have 2 PCs, you can use ESP32-S2/S3 and have 100% detection avoidance.
      Any updates with this? I am also still banned from EA games due to REWASD installed while I was playing Battlefield 6 since November.
        Nothing to report yet.
