Shotgun Recoil Issue
  • Shotgun Recoil Issue
    I'm playing a game that has a shotgun it in.
    So here's the issue:
    When I press fire it has recoil that shoots the aim up after every shot pressed.
    So i then set the right stick to -40 deflection
    So, on a single press this doesn't work because each time I shoot nothing stops the recoil, its still going upwards after each trigger press
    Now when I put turbo on, it kinda works but I have to hold the trigger down and when holding it down, this happens:
    Shot fires
    Recoil is brought down
    Recoil keeps going down because it takes 1.25 seconds to fire the next shotgun bullet as it has a cooldown
    (So this takes recoil lower and lower)
    I want to make it work on a single press, is this possible and how can i do this?
    Or even if we can fix it on turbo/hold down mode that would be good too but I would prefer single press.
    Remap [Start Press] activator to a [Combo] of shot-button and the stick being held down for a specific time instead of always.
      How do I make the stick being held down for a specific time instead of always?
        This [Combo] will shoot and hold the right stick down for 1 second at 10% deflection:
        You might need to adjust stick deflection and the value of the last pause node (it sets how long the stick should be held down).
          Thank you!
