macro delay can't adjust.
  • macro delay can't adjust.
    Combo -> any key -> Add pause -> Can't adjust pause time by using "UP or DOWN arrow", even using keyboard to input the timer
    But others that using "UP / DOWN arrow" suck like "Delay between keys" "Iterations" works fine.
    Hi!
    Manually download and update to the latest version of reWASD from our site.
      Update to 9.3.2.10960. Problem solved.
      Thank You!
