Upgrade from 9.13 >>> 9.32
When i try to upgrade that (download from pakeage not using the upgradde button from the app because it is too slow) , it return a fail upgrade, then i reboot and reinstall again no problem but crashed when starting the app.
i forget what i did after but i manage to make it(9.32) run but new problems are found.
For the 9.13v
my mouse basic mouse key(lmb,rmb... xbutton1/2 and wheelup and down) is hook by rewasd as a mouse basic device.
for the rest of the mouse keys are emu as a another keyboard device which rewasd can also hook and remap it.
I group them to my other real keyboard , working fine
For the 9.32
When i enable the mouse basic device(rewasd), my rest of mouse keys will be muted !!
Meaning enable the mouse basic key device that will shut down my mouse other key's native driver.
That(problem) doesn't matter if the emu keyboard is enabled(rewasd) or not, it can be hook and remap again only if the mouse basic device is not hooked by rewasd.
(this problem is not present after roll back to 9.13)
And for that real keyboard , somehow it group itself as a group, reset itself with a genertic keyboard name, it can not be ungroup , it is not detectable in the group list. but if i keep messing with it there is a chance(very low) that will reappearing in the group list which i can add my mouse back to it . (this problem is present after roll back to 9.13)
I am not interest to reset anything and will stay at 9.13. as i am afraid there is a chance that will make my mouse detectable or unusable so i will leave it this way.
It is not a big deal to me but i still report this anyway as a bug is a bug.
For the 9.13v
For the 9.32
