download 9.3.3, have tried downloading all sorts of .net runtimes and asp.net core runtimes, will come up with initial UAC window, I click yes, then just nothing. This is with Real-time protection turned off. Check event log, just keep getting this Event Log error Event ID 1026:
help please? I've used the software on this PC before (have eliminated any files related to it now) and am a legacy account owner
Code:
Application: reWASD933-11019.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.BadImageFormatException at Engine.NET.Base.Utils.Settings.FileStorage..ctor(S ystem.String, System.String) at Engine.NET.Base.Utils.Settings.FileSettingsStorage ..ctor() at Engine.NET.Base.Utils.Settings.Settings.get_Settin gsStorage() at Engine.NET.Base.Utils.Settings.Settings.GetValue(S ystem.String, System.String, Int32, Boolean) at Engine.NET.Base.Utils.DSUtils.GetUserLocaleID() at RewasdWpfInstaller.App.OnStartup(System.Windows.St artupEventArgs) at System.Windows.Application.<.ctor>b__1_0(System.Ob ject) at System.Windows.Threading.ExceptionWrapper.Internal RealCall(System.Delegate, System.Object, Int32) at System.Windows.Threading.ExceptionWrapper.TryCatch When(System.Object, System.Delegate, System.Object, Int32, System.Delegate) at System.Windows.Threading.DispatcherOperation.Invok eImpl() at System.Windows.Threading.DispatcherOperation.Invok eInSecurityContext(System.Object) at MS.Internal.CulturePreservingExecutionContext.Call backWrapper(System.Object) at System.Threading.ExecutionContext.RunInternal(Syst em.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threa ding.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threa ding.ExecutionContext, System.Threading.ContextCallback, System.Object) at MS.Internal.CulturePreservingExecutionContext.Run( MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object) at System.Windows.Threading.DispatcherOperation.Invok e() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(In tPtr, Int32, IntPtr, IntPtr, Boolean ByRef) at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef) at MS.Win32.HwndSubclass.DispatcherCallbackOperation( System.Object) at System.Windows.Threading.ExceptionWrapper.Internal RealCall(System.Delegate, System.Object, Int32) at System.Windows.Threading.ExceptionWrapper.TryCatch When(System.Object, System.Delegate, System.Object, Int32, System.Delegate) at System.Windows.Threading.Dispatcher.LegacyInvokeIm pl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr) at MS.Win32.UnsafeNativeMethods.DispatchMessage(Syste m.Windows.Interop.MSG ByRef) at System.Windows.Threading.Dispatcher.PushFrameImpl( System.Windows.Threading.DispatcherFrame) at System.Windows.Threading.Dispatcher.PushFrame(Syst em.Windows.Threading.DispatcherFrame) at System.Windows.Application.RunDispatcher(System.Ob ject) at System.Windows.Application.RunInternal(System.Wind ows.Window) at System.Windows.Application.Run(System.Windows.Wind ow) at RewasdWpfInstaller.App.Main()
