the app is always bugged at windows start. It's in the tray but I can't open the window. Not with double click and also not with right click and "open reWASD".
I have to close the reWASD app and then start it again. Then I can open the app to choose a profile or make changes.
(probably caused by a win update or something) But the problem exists for some time.
There is also a problem with the (stupid) LED light on my Flydigi Vader4 Pro. It is constantly bright as hell. I didn't set this up and in the controls it says NONE. I can change it but then it still is bright as...eff. (
did you get support by an energy company) I know...stupid joke.
At least in Crimson Desert the controller sometimes reacts clumsy. But it can also be just the game. As there are also issues with other apps like my Razer Mouse and Keyboard.
A "solution" for now is setting the LED settings to "solid" and choosing as RGB code 0 0 0.
(something's wrong with the setting NONE)
But I noticed that reWASD has a nice function for me at hand when I use multiple layers to see what layer is turned on
(flydigi's app was buggy with this the last time I tried...yours seem quite well working)
Before the LED issues started I had to reinstall the app to keep it working. But the LED issues did start later. Today I noticed the LED issues. The last time I used my controller was around 25th April. (know that date because I looked for a solution for a problem and had to reinstall the app)
Overall the tool runs. so it's just some annoyance as for now I could find some dirty tricks to solve the issues.
did you get support by an energy company) I know...stupid joke.At least in Crimson Desert the controller sometimes reacts clumsy. But it can also be just the game. As there are also issues with other apps like my Razer Mouse and Keyboard.
(flydigi's app was buggy with this the last time I tried...yours seem quite well working)Before the LED issues started I had to reinstall the app to keep it working. But the LED issues did start later. Today I noticed the LED issues. The last time I used my controller was around 25th April. (know that date because I looked for a solution for a problem and had to reinstall the app)
