Gyro Shake
  • Gyro Shake
    I'm playing Metal Gear Solid 4 on my RPCS3.The game requires you to shake your controller up & down for various actions.
    I'm using a 3rd Party Generic Xbox based controller called Thunderobot G50S. This controller comes with plenty of extra buttons to remap things. They give you a Mode to remap controllers innately on the controller itself as their way to remap your own buttons.
    I have the paid version of reWASD & I'm wondering if I can remap the PS3 Gyro Up & Down shake function to any of these free "M1-6" Buttons on the controller itself. My main goal is to have my controller be able to shake without a gyro somehow.
    Secondary goal if that's possible to macro/Combo me shaking the controller up and down for however long the macro lasts assuming it's not executing it "All at once" but hold and go with some brief pauses between each shake.
    Lastly, if I can just use these M1-6 extra buttons on this controller as detectable programable buttons in reWASD to just have extra select buttons or move my X button to an M button somewhere.
    Thanks
