reWASD losing a physical pad from a group after restart
  • reWASD losing a physical pad from a group after restart
    First time using reWASD, and I have an issue with a simple config on Windows 11 when creating 2 pairs of gamepads for 1 on 1 local player battles, each with a team mate, without controller swapping.
    Config is like this:
    Physical xbox360 pad 1 + physical xbox360 pad 2 ---> group 1 ---> output to xbox360 virtual pad 1.
    Physical xbox360 pad 3 + physical xbox360 pad 4 ---> group 2 ---> output to xbox360 virtual pad 2.
    Pressing a button on pad 1 and/or the same button on pad 2 produces the same button press on the virtual pad 1. Same for axes D-pad, everything. All mapped 1:1
    Pressing a button on pad 3 and/or the same button on pad 4 produces the same button press on the virtual pad 2.? Same for axes D-pad, everything. All mapped 1:1
    I can prove this works in Windows 'Setup USB Game Controller' app 'joy.cpl'.
    Virtual pad 1 is affected by physical xbox360 pads 1 & 2, and Virtual pad 2 is affected by physical xbox360 pads 3 & 4, fantastic.... that is until I restart Windows.
    After a restart, one of the gamepads in group 2 is showing as disconnected, it's greyed out, but another pad has appeared outside of any group!
    So now there's five pads known to reWASD:
    Two connected in group1.
    One connected in group2.
    One dis-connected in group2 (greyed out).
    One new pad outside any group.
    Windows 11 is the latest build.
    All Physical xbox360 pads are connected to individual ports on the PC mainboard, no external USB hubs are used.
    I suspect this is a windows 11 hardware ID assignment thing?
    Thanks.
